2003 Windstar SE High Beam Issue
Hi All
I just purchased a 2003 Windstar SE and i'm having issues with left-high-beam, that is not working. The passenger side works ok. Please note that both sides low beam work OK
* When the headlight is off, high beam works on both sides
*When the park-light is on, high beam works on both sides
*When the headlight is on, only passenger side high beam works.
What is the problem here?
No, it does not have DTRL system. Is headlight module same as the multifunction switch?
I've replaced the bulb, it did not help. High beam work when all lights are off and works when parking lights are on.
so the problem is the left high beam does work...
When I push the control lever (the one control signals, high beam etc), both low beam works, but no high beam on left
When I pull the control lever like i'm flashing, no low and high beams on the left side (right side works fine).Then i played with the headlight socket low beam comes on, but still no high beam
It looks like the socket does not function as it should.What do you all think?
vanlegr
03-04-2008 08:02 AM
