Engine Surges When Stopped at Light
Old 05-03-2011 | 02:22 PM
chipsdad56's Avatar
Default Engine Surges When Stopped at Light
1996 Windstar with 3.8 and 101,000 miles. Starts fine and idles fine in park or neutral. When I put it in drive or reverse it will either stall or the idle will surge between about 500 rpm and 900 rpm. This also happens when slowing and stopping for a light. I changed the AIS with new Motorcraft and sprayed the MAF with cleaner but this has not solved the problem. Air filter is good. What do I check next? Thanks.
Old 06-21-2011 | 10:49 PM
manuel.farrar@yahoo.com's Avatar
Sounds like a gasket leak around the manafold !
worriedforddriver
01-26-2011 07:52 PM
sweener
01-12-2010 12:24 AM
4Duh
09-06-2007 07:59 AM
tanklord
04-01-2007 08:39 PM
95okexpolorer
05-28-2005 12:41 AM
