Front Subframe rust
Front Subframe rust
I have a 2001 with the typical front sub frame rust problem at the rear brackets worse on the drivers side. the fronts are solid, Ford did the so called repair and put on the reinforcement parts, my question is will do these brackets hold? has anyone had a failure after the fix? the rest of the front end is solid other than needing a bearing. I am debating if I'm going to sell this van or not.
