head gasket bad is it worth diy or engine swap
RE: head gasket bad is it worth diy or engine swap
Assuming 3.8?
Ford has a re-engineered head gasket set, as well as a reinforced timing cover gasket thats prone to fail.. A H/gasket change is a good time to do both head/timing if it hasn't been done already.. If this has had 'repeat' head gasket failures, could be the quality of parts used, or service.. Torque to yield head bolts 'must' be replaced during a gasket replacement or an early failure can/will occur.. Heads checked for flat, and/or machined.. If the upgrade gaskets weren't used, new headbolts, heads/deck checked for flat or even damage from 'gasket removal' (some shops use abrasive discs) then the best service life you can expect is only as good as the original set, or less.. What shop did the previous work??
Somethings wrong with the 'quality' of repair, or it would have to be driven pretty hard or get hot to need 4 sets of head gaskets...Even three!!
sexyxxxrebelxxx
06-11-2010 10:41 PM
