WINDSTAR 2002 ABS BRAKES lights
Old 06-03-2014 | 07:58 AM
kamleshkumar_darbar's Avatar
Default WINDSTAR 2002 ABS BRAKES lights
Hi,
I have a Ford Windstar 2002 and when I drive the ABS and the BRAKE lights keep comming on.
Please can you advice me on how do I check this out and what is causing this to happen.
Also how much is the ABS EBCM for a ford windstar and can it be repaired.
The vin no is 2FMZA52442BB70652.
I look forward to hearing from you.
Regards,
Kamleshkumar Darbar
Old 06-03-2014 | 02:13 PM
katie85's Avatar
Most probably needs a new abs module, cost around £300/£400. If you google it its apparently safe to drive as it is.
Hope that helps
Old 06-03-2014 | 03:48 PM
bluewind's Avatar
to provide additional detail:
you should check if the the brake pressure switch that sits at the underside of the master cylinder is leaking brake fluid. You find it if you look over the air filter housing towards the firewall.
Make this a regular check or replace it immediately if there is a leak. Ford had a recall on this. If brake fluid leaks it will run down the wires and enter the harness at the ABS module. That stuff attracts water and this can cause a short resulting in fire.
The second issue its the ABS module itself. The printed circuit board is cracked and when the temperature goes up it disrupts some internal circuits. The ABS light comes on. In this situation you have regular brakes, no ABS.
There is no recall on this. Either live with it, replace it (about $1000 job) or have the ABS module repaired by for example: Automotive Scientific Inc. Your #1 Source for ECU, TCU, ABS, EBCM, Climate Control and Speedometer Repairs
willy j
09-30-2013 07:42 PM
ranshells
01-14-2011 11:13 AM
Hutch64
05-31-2007 09:21 PM
stamour46
01-22-2006 05:18 PM
jessie3
08-02-2005 10:15 AM
Quick Reply: WINDSTAR 2002 ABS BRAKES lights
